FOURVARIATE GARCH BEKK MODEL
danchris2015
Postby danchris2015 » Sun Sep 06, 2015 4:41 am
I am trying to run a FOURVARIATE GARCH BEKK MODEL, however I encountered a problem at the very last part. The error message reads ' Overflow in scalar lr = -2*(eq1.@logl + eq2.@logl + eq3.@logl + eq4.@logl - fvgarch.@logl ) ). Here the alphas and betas have an initial value of 0.1. I tried to change to alpha and beta to 0 however, then an other message reads ' positive or non-negative arguments to function expected in scalar lr_pval = 1 - @cchisq(lr,4). Would you please suggest any solution to any of these two error messages
Thank you
FV.prg
(10.24 KiB) Downloaded 346 times
Macro.wf1
(246.29 KiB) Downloaded 285 times
trubador
Did you use forum search?
Re: FOURVARIATE GARCH BEKK MODEL
Postby trubador » Mon Sep 07, 2015 1:39 am
Error messages are pretty clear. Scalar lr either end up with a very large or a negative number. I do not think playing with the starting values would be of much help. You are trying to build a very complicated framework with monthly data. Data span is very short and y3-y4 do not even have significant univariate GARCH effects. I believe the model is ill-defined and you'll have to figure it out on your own.
danchris2015
Postby danchris2015 » Mon Sep 07, 2015 6:35 am
Thank you for your message. Could an increase in frequency be the solution?
