Hello, I succesfully estimated an SSpace model of the following form:
Y = H*X + w
X = F*X(-1) + e
The model has 7 signal equations and 30 state variables (including the auxiliary ones like X1=X(-1))
Now I am trying to compute the following matrix (M):
M = (I-(I-K*H)*F)^(-1)*K
where (matrix dimensions in [ ])
I = @identity(s)
K = Kalman Gain [s,y]
H = Signal equation parameter matrix [y,s]
F = State equation parameter matrix [s,s]
s = # of state variables in the system
y = # of signal equations in the system
In order to do so, I need to understand well how Eviews structure the F,H and K matrices so here are my questions (Im calling "model" the Sspace obejct):
1) Are F and H in a structure like the one displayed in the matrix using model.structure? In this case, this matrix would correspond to F stacked above H.
2) How can I put the view model.structure into a matrix that I can manipulate?
3) The kalman gain (model.@curr_gain) is displayed in a @vec for each period. I need to @unvec it in an [s,s] matrix. If I do so, would it be consistent with the structure of F if (1) is true?
Please help!
(Im using Eviews 9)
SSpace structure
SSpace structure
Re: SSpace structure
1. yes, but with the state equation offset by one period (see the manual for discussion)
2. you'll have to create the matrix yourself -- you should be able to copy-and-paste
3. yes
3. yes
Thank you for your help.
So the only way to work with the structure matrix is by copying it "by hand" using copy-paste?
Actually, I would expect the following command to do the trick, but it does not:
Anyway, you can always create a blank matrix (e.g. smat) and fill in the values via copy-and-paste.
ttom(model.structure,smat)-
You can use ttom but if you use the coefficient view you can run into trouble. If you use the value view, it should work.
ttom(model.structure(v),smat)Return to “General Information and Tips and Tricks”
