Eviews 9 crashes when loading data in SAS file
Postby tvonbrasch » Thu Aug 13, 2015 1:16 am
Im loading several SAS (sas7bdat) data files. Most of the files are less than 5 GB. However, when loading a data file that is 8.5 GB Eviews just stops working. I have kept an eye on the amount of memory used by Eviews, but it is much less than what is available on the network (20 GB). I am therefore not sure what is causing this error.
Unfortunately, I cannot send you this data due to confidentiality.
When loading the file, I can first choose which variables to read. Then Eviews starts to read the series. After abut 68% is remaining, it stops working (see image).
Do you have an idea what can be causing Eviews to crash? Is there anything I can do to find out what the error is?
Eviews crashes.jpg (318.97 KiB) Viewed 4502 times
Re: Eviews 9 crashes when loading data in SAS file
Postby EViews Gareth » Thu Aug 13, 2015 7:52 am
We'd like to recreate this somehow. Can you give some indication of the structure of the SAS file? How many series? How many observations?
Postby tvonbrasch » Fri Aug 14, 2015 2:21 am
Hi, there are 76 series and 11 684 454 observations for each series.
If I only open four of the series, it works fine. (and I only need four of them, so my problem is solved).
hope you figure out what is causing this problem
(im running Eviews 9 64-bit)
Postby startz » Fri Aug 14, 2015 4:53 am
tvonbrasch,
How much memory do you have on your machine? I'm wondering if you're running out of memory, not that that should cause a crash.
Postby tvonbrasch » Fri Aug 14, 2015 6:23 am
The program is running on a network drive with 20 GB of memory. I have watched the memory usage while loading the data set, and (as far as I can see) the problem is not caused by to little memory.....
