Version: Eviews 8.1, standard edition, Apr 27 2015 build, 64-bit on Win7 Professional
I extract smoothed probabilities from a Switching regression using the command:
eq.makergmprobs(type=smooth) series1 series2 series3
When I open one of the series, in the top pane of the spreadsheet it says that the last modification was
eq.makergmprobs(type=filt) series1 series2 series3
I can confirm that extracting the actual filtered probabilities differ from those extracted with smoothed, so it's likely a typo and not the wrong probabilities that comes out, but can you confirm this?
Switchreg smoothed probabilities
Re: Switchreg smoothed probabilities
Just verified that it's a labeling issue.
Will fix the labeling in EViews 9. You can verify for yourself by extracting to each of the types
and comparing results.
eq.makergmprobs series1o series2o series3o
eq.makergmprobs(type=filt) series1f series2f series3f
eq.makergmprobs(type=smooth) series1s series2s series3sWho is online
