Covariance matrix of coefficients with GARCH models
strypste
Postby strypste » Sat Jul 04, 2015 7:07 am
HI there
I estimated a GARCH model and now I want to calculate the variance covariance matrix of the coefficients (I can obtain this by View -> Covariance matrix). HoBut how is this calculated in Eviews?
As there is a constant in the mean and variance equation, X'X is not invertible, where X is a matrix of all the regressors in the model. So how can we possible do this?
Best
S
Re: Covariance matrix of coefficients with GARCH models
Postby startz » Sat Jul 04, 2015 9:15 am
A thoughtful question, but why do you think X'X is not invertible? The variables in the mean and variance equations don't enter linearly.
strypste
Postby strypste » Mon Jul 06, 2015 2:58 am
Hi Startz
Thanks for your answer. So how can I calculate it then? I looked online and textbooks, but was unsuccessful in finding an answer. Any references?
Best
s
Postby startz » Mon Jul 06, 2015 6:26 am
I believe the GARCH variance is just the usual maximum likelihood variance estimator, but maybe one of the EViews folks or Trubador could chime in.
trubador
Did you use forum search?
Postby trubador » Mon Jul 06, 2015 1:19 pm
Startz is right. You can try the following and see it for yourself:
'Create a workfile wfcreate u 1000 'Generate an exogenous series series x = nrnd 'Generate a y series that follows a GARCH-X(1,1) dynamic (use TSDGP add-in) tsdgp(meanconst="5",meanexog="2*x",varconst="1", arch = "0.08", garch="0.91") y 'Estimate the model equation eq.arch(backcast=1) y c x 'Save the gradients and store as a matrix eq.makegrads(n=grads) stom(grads,gradmat) 'Compute the covariance matrix (OPG) sym varcov=@inverse(@transpose(gradmat)*gradmat) 'Save the covariance matrix from the estimated equation for comparison sym eqcov = eq.@coefcov
strypste
Postby strypste » Mon Jul 06, 2015 2:43 pm
Brilliant! Thanks you so much for this. Very much appreciated!
Best
s
