Error Message
kcaron
Error Message
Postby kcaron » Wed Jun 17, 2015 8:06 am
I'm trying to do a forecast based on an AR model.
When I click on the forecast button I get the following error message:
"NONE: was not found."
Any idea why this might be?
Thank you!
Re: Error Message
Postby EViews Gareth » Wed Jun 17, 2015 8:17 am
Can you provide the workfile?
kcaron
Re: Error Message
Postby kcaron » Wed Jun 17, 2015 8:18 am
It has some Bloomberg links..
wca diffusion index.wf1
(1.75 MiB) Downloaded 301 times
Re: Error Message
Postby EViews Gareth » Wed Jun 17, 2015 11:22 am
Got it. Possibly a bug, we'll investigate.
If you convert the barometer_total series into a series rather than a formula (open it up, click on Properties, then the Values tab, then change to "numerical data", then re-estimate the equation, then forecast it should work in the meantime.
Re: Error Message
Postby EViews Glenn » Wed Jul 01, 2015 3:03 pm
Today's update should fix this. The problem was that the database expression inside of the dependent variable formula contains a quoted string and that case wasn't being handled cleanly.
[edit: sorry, it wasn't in the the 7/1 patch but will be in the next]
