group - add: adding the same series more than once
mamo
Postby mamo » Wed Apr 22, 2015 1:58 am
Dear Eviews team,
the following is a minor issue
Eviews version: Eviews 8.1 64 bit
Issue: One cannot program adding one and the same series more than once to the same group
Example:
mygroup.add x x
would result in x showing up only once in the group mygroup
In contrast, x can be added to the group more than once via the group members menu.
Workaround:
One may add x and an idempotent transformation of x, such as
mygroup.add x x+0
Suggestion:
Allow for adding the same series more than once to the group
Remark: let mygroup contain two instances of x. After
mygroup.drop x
mygroup contains one instance of x - as I expect.
This seems to somehow contrast with the logic behind the add procedure.
Remark:
Certainly a minor issue; the option of having one series more than once in the same group may be convenient, in particular when mangaging large groups
Best,
mamo
Re: group - add: adding the same series more than once
Postby EViews Glenn » Wed Apr 22, 2015 10:47 am
I agree. I've made a preliminary update to EV9. It'll go to testing and if all is well, will appear shortly in an EViews 9 patch.
Postby EViews Jason » Mon Jun 01, 2015 1:58 pm
As of the latest patch (May 29, 2015), you will need the 'dup' option to add a series more than once.
mygroup.add(dup) x x
