conditional covariance with mgarch dcc
ayca79
Postby ayca79 » Fri Apr 24, 2015 2:04 am
I need to find conditional covariances between two variables. My method is mgarch dcc. When I run mgarch dcc codes, it produces garch(1), garch(2) and rho. I calculate covariance as
covariance=rho*(garch(1)*(garch(2))
as the codes don't produce covariances, it must be the way to estimate covariances .
However, I also estimated the covariances with mgarch ccc which produces the covariances. And mgarch ccc produces better results than dcc in my research so I felt dubious whether covariance=rho*(garch(1)*(garch(2)) might be wrong or I have missed something.
Thank you very much,
trubador
Did you use forum search?
Re: conditional covariance with mgarch dcc
Postby trubador » Sat Apr 25, 2015 3:36 am
You should take the square roots of variances before multiplying them to compute the covariance.
ayca79
Postby ayca79 » Wed May 06, 2015 7:09 am
Thank you. I took squareroots of garch series when multiplying the conditioanl covariances. But I wrote in the post without the square roots by mistake. So I did it right then. Thank you.
BISMA
Postby BISMA » Wed Jan 11, 2023 2:55 am
Hello! My name is Bisma Raina.
Could you kindly share the codes of mgarch DCC?
Thank you.
