Hi.
The following program was working normally on Eviews 6 and 8, but not in Eviews 9.
With !obs=100 it works a few times.
But never with !obs=1000
!obs = 100
wfcreate u !obs
rndseed 1
smpl 25 !obs
series e = nrnd
series x1 = 100*rnd
series x2 = 30*nrnd
series x3 = -4*rnd
group xs x1 x2 x3
smpl 25 !obs-1
series y = 3 + 2*x1 + 4*x2 + 5*x3 + e
smpl @all
' set window size
!window = 35
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq01
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'matrix to store coefficient estimates
matrix(4,!nrolls) coefmat ' where 7 is the number of coefficients
'series to store forecast estimates
series eq01fcast
'redundant series for catching start and end points
series ser = 1
%start = @otod(@ifirst(ser))
%end = @otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 25 to !length-!window+1-!step step !step
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start)+!i-1)
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is y=c(1) + c(2)*x1 + c(3)*x2
eq01.ls y = c(1)*x1 + c(2)*x2 + c(3)*x3 + [AR(1)=C(18)]
' store coefficients
colplace(coefmat,eq01.@coefs,!j)
' 4-period-ahead forecast
%4pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%4pere = @otod(@dtoo(%start)+!i+!window-1) 'end point: %4pere - %4pers +1 = 1
if @dtoo(%end) < @dtoo(%4pere) then 'check whether the forecast end point is greater than the workfile end point
return
endif
' set smpl for forecasting period
smpl {%4pers} {%4pere}
' forecast with command *forecast* (see also *fit*)
eq01.fit(f=na) yf
' set sampl to obtain the 4th period observation
smpl {%4pere} {%4pere}
' store forecasts
eq01fcast = yf
'FORECAST IN-SAMPLE
smpl @all
eq01.fit(f=actual) yf2
d(noerr) ser
series yf3 = y
smpl !obs !obs
series yf3 = yf2
smpl @all
Eviews 9 - convergence problems
Re: Eviews 9 - convergence problems
We're testing a fix for this. Stay tuned.
[Edit: a fix is available in today's patch].
lfpazevedo
The problem was not solve.
Try this code. It is working well on Eviews 6, but not on Eviews 9
wfcreate m 2005M01 2015M12
rndseed 1
smpl @first+25 @last
series e = nrnd
series x1 = 100*rnd
series x2 = 30*nrnd
series x3 = -4*rnd
group xs x1 x2 x3
smpl @first+25 @last-1
smpl @all
' set window size
!window = 35
' set step size
!step = 1
!length = @obsrange
equation eq01
matrix(16,!nrolls) coefmat ' where 7 is the number of coefficients
series eq01fcast
series ser = 1
!j=0
!j=!j+1
eq01.ls y = c(1)*x1 + c(2)*x2 + c(3)*x3(-1) + [AR(1)=C(4)] + C(11) + C(12)*@SEAS(1) + C(13)*@SEAS(2) + C(14)*@SEAS(3) + C(15)*@SEAS(4) + C(16)*@SEAS(5) + C(17)*@SEAS(6) + C(18)*@SEAS(7) + C(19)*@SEAS(8) + C(20)*@SEAS(9) + C(21)*@SEAS(10) + C(22)*@SEAS(11)
return
endif
eq01.fit(f=na) yf
' store forecasts
eq01fcast = yf
'FORECAST IN-SAMPLE
smpl @all
d(noerr) ser
series yf3 = y
smpl @last @last
series yf3 = yf2
smpl @all
rndseed 1
series e = nrnd
series x1 = 100*rnd
series x2 = 30*nrnd
series x3 = -4*rnd
group xs x1 x2 x3
smpl @all
' set window size
!window = 35
' set step size
!step = 1
!length = @obsrange
equation eq01
series eq01fcast
series ser = 1
!j=0
!j=!j+1
return
endif
eq01.fit(f=na) yf
' store forecasts
eq01fcast = yf
'FORECAST IN-SAMPLE
smpl @all
d(noerr) ser
series yf3 = y
smpl @last @last
series yf3 = yf2
smpl @all
edit to delete unhelpful advice
The previous bug was fixed. What you are reporting now is a different issue than the previous post.
What's going on now is that the syntax parser is no longer handling the "[ar(1)=c(4)] in the middle of the expression. I'll work on tracing down the change and getting a fix. For now, if you move that part of the expression to the end of the line, your program will run to completion.
Sorry, that one was me. The earlier fix caused problems when you had, as in the example, an explicit AR regression with the AR portion of the specification in the middle of the expression. That one wasn't in my set of tests.
As I said, for now, if you put the AR portion at the end of the spec, you'll be fine. You'll find a fix in the next patch. Sorry for the inconvenience.
lfpazevedo
Thanks!
It is working now.
It is working now.
