Probit model forecasting via command line
trubador
Did you use forum search?
Postby trubador » Fri May 01, 2015 2:09 am
Command capture shows the following syntax for fitting probability and index from a probit model:
{%equation}.fit(d, g) prob {%equation}.fit(d, i, g) index
If execute them from the command line, they both produce the same results (of the index actually).
Re: Probit model forecasting via command line
Postby EViews Glenn » Fri May 01, 2015 2:12 pm
It'll be fixed in the patch following today's.
