Dubin 1998 Replication
For posting your own programs to share with others
CharlieEVIEWS
Postby CharlieEVIEWS » Thu Apr 16, 2015 1:02 pm
This code replicates part of Dubin (1998) - Spatial Econometrics, A Primer. The .txt attachment is the values of their (simulated) distance matrix (to check for congruence of results). Please feel free to post any questions below and I'll do my best to answer.
Charlie
''This is a file to replciate the first half (SEM part) of Dubin (1998) in JoHE %cd = Change your CD here 'Set up the distance matrix wfcreate(wf=durbinreplication) u 1 matrix(10,10) distance distance.read {%cd}\durbindistance.txt !lamda1 = 0.33 !lamda2 = 0.67 for !l = 1 to 2 for !p = 1 to 3 matrix(@rows(distance),@columns(distance)) w_{!p}_{!l} for !a = 1 to @rows(w_{!p}_{!l}) for !b = !a to @rows(w_{!p}_{!l}) if !a<>!b then w_{!p}_{!l}(!a,!b)=1/distance(!a,!b)^(!p) w_{!p}_{!l}(!b,!a)=w_{!p}_{!l}(!a,!b) endif next next for !a = 1 to @rows(w_{!p}_{!l}) !temp = @csum(@transpose((w_{!p}_{!l})))(!a) for !b = 1 to @rows(w_{!p}_{!l}) if !a<>!b then w_{!p}_{!l}(!a,!b)=w_{!p}_{!l}(!a,!b)/!temp endif next next matrix V_{!p}_{!l} = @inverse(@identity(10)-(!lamda{!l}*w_{!p}_{!l}))*@inverse(@identity(10)-(!lamda{!l}*(@transpose(w_{!p}_{!l})))) matrix(@rows(V_{!p}_{!l}),@columns(V_{!p}_{!l})) C_{!p}_{!l} for !a = 1 to @rows(C_{!p}_{!l}) for !b = !a to @rows(C_{!p}_{!l}) C_{!p}_{!l}(!a,!b)=V_{!p}_{!l}(!a,!b)/@sqrt(V_{!p}_{!l}(!a,!a)*V_{!p}_{!l}(!b,!b)) next next matrix(((@rows(C_{!p}_{!l})-1)*@rows(C_{!p}_{!l}))/2,2) output_matrix_{!p}_{!l} !c = 0 for !a = 1 to @rows(C_{!p}_{!l}) for !b = !a to @rows(C_{!p}_{!l}) if !a<>!b then !c = !c+1 output_matrix_{!p}_{!l}(!c,2)=C_{!p}_{!l}(!a,!b) output_matrix_{!p}_{!l}(!c,1)=distance(!a,!b) endif next next freeze(output_graph_{!p}_{!l}) output_matrix_{!p}_{!l}.scat show output_graph_{!p}_{!l} next next
dubindistance.txt
(466 Bytes) Downloaded 13038 times
Return to “Program Repository”
