Problem in transforming .spc file into Eviews code.
victor.alves
Postby victor.alves » Thu Apr 16, 2015 10:57 am
In Eviews8 I mannualy created a setting of seasonal adjustment from "proc/seasonal adjustment/Census x13". I Checked the box to save the spec file, which gave me text object (below). As I will regularly use this setting to adjust the series I was transforming this spec file into this eviews code:
PIB.X13(savespc=TESTE4, save="D11", tf=log, arimasmpl="1996Q1 2014Q4", flen=6, forclognorm) @REG(regs="TC1996.3,AO1998.1,LS2008.4,TC2009.1,Easter[15]") @ARIMA(model="(0, 2, 2)(0, 1, 1)") @X11(mode=mult)
However, when run it and save a new spec file to check what was done, it shows that the dummies ("TC1996.3,AO1998.1,LS2008.4,TC2009.1,Easter[15]") were not considered. I couldn't fix it. Any thoughts?
I also tryied to save the spec file as .spc and run a series.X13 (sfile="C:\..") programm but it just ran a regular x13 with no settings in it. Is the sfile command available to X13 or only to X12?
Thank you.
series{
title = "PIB"
start = 1996.1
period = 4
modelspan = (1996.01, 2014.04)
name = "PIB"
file = "C:\Users\874008\AppData\ev_temp\EVX13TMP.DAT"
decimals = 1
transform{
power = 0
arima{
model = (0, 2, 2)(0, 1, 1)
regression{
variables = (
TC1996.3
AO1998.1
LS2008.4
TC2009.1
Easter[15]
forecast{
maxlead = 6
lognormal = yes
save = (fct, bct)
x11{
mode = mult
save = (d11)
EDIT: Spelling
Re: Problem in transforming .spc file into Eviews code.
Postby EViews Gareth » Thu Apr 16, 2015 11:23 am
What's the build date of your copy of EV8?
victor.alves
Postby victor.alves » Thu Apr 16, 2015 12:20 pm
Oct 22 2013 buid.
Postby EViews Gareth » Thu Apr 16, 2015 2:05 pm
Update to the latest version.
victor.alves
Postby victor.alves » Mon Apr 20, 2015 1:39 pm
I upgraded to Eviews 9 (14-april-2015 build). Now the command line worked just fine. Thanks.
