stochastic volatility using kalman filter
saizal87
Postby saizal87 » Thu Apr 02, 2015 8:39 pm
Hi, i m interested in estimating stochastic volatility of stock return (y) using kalman filter. But i m not so sure with the process. Currently im using this coding from the internet:
@signal y = -1.27 + s + [var=4.9348]
@state s = c(1) + c(2)*s(-1)+[var=(3)*2]
param c(1) -10.8720 c(2) 0.2736 c(3) 4.9532
where;
-10.8720 = parameter for constant through ols
0.2736 = y(-1) parameter through ols
4.9532 = s.e of ols egression.
Can anyone explain either -1.27 and 4.9348 are standard for kalman. And what does it represent? When i estimate, i have insignificant (c1, c2 n c3)! estimation, does it suggests that the model does not hav stochastic volatility? I am new with eviews and i really hope that someone could help me. Thanks in advance. Saizal.
trubador
Did you use forum search?
Re: stochastic volatility using kalman filter
Postby trubador » Fri Apr 03, 2015 2:01 am
You should be asking these questions to the author of the code.
If you had done a search in the forum, you would have found the following: http://forums.eviews.com/viewtopic.php? ... 744#p24051
terrya
Postby terrya » Fri Apr 03, 2015 9:43 pm
where;
You need to look at the paper by Harvey, Ruiz and Shephard, Multivariate stochastic variance models, Review of Economic Studies, 1994, Vol 61, 247-264, to find the reasoning for the formulation.
terrya
Postby terrya » Fri Apr 03, 2015 9:55 pm
where;
Trubador's approach works. I've used a variant of his in the past. However, I estimated the starting values of the parameters by using a Box-Jenkins AR1 model.
saizal87
Postby saizal87 » Sat Apr 04, 2015 12:02 am
