Resample
npc
Resample
Postby npc » Mon Mar 04, 2013 6:19 am
I am new to Eviews and want some help with the resample function.
If possible I want to create 1,000 resamples from an original sample (series) that has 5,000 observations. I also want each resample to be a separate series, or preferably for all the resamples to form a single matrix (i.e. 1000x5000).
If anyone is able to point me in the right direction that would be much appreciated.
Re: Resample
Postby EViews Gareth » Mon Mar 04, 2013 8:40 am
Have to use a program. Here's an example:
create u 5000 series x=nrnd 'resample 1,000 times. for !i=1 to 1000 x.resample x!i next
npc
Re: Resample
Postby npc » Thu Mar 07, 2013 7:38 am
Thanks, that's great just what I needed.
Imitation
Re: Resample
Postby Imitation » Sun Mar 22, 2015 5:01 pm
Hi, I have similar problem, but in my case I'm resampling with block size=30. So some part of the code is as follows:
rndseed 12345
series open
matrix(1,1563) m1
stom(open,m1)
!nreps=1000
matrix (1563,1000) x
for !i = 1 to !nreps
@resample (m1,0,30)
The problem is I can't store samples from each iteration. I guess it should be something like this in the loop, but it doesn't work:
'store coefficients into matrix
colplace(resample, resample.@resample, !i)
Could you please advice on that, Thanks!
Re: Resample
Postby EViews Gareth » Sun Mar 22, 2015 5:31 pm
You have to set a matrix equal to the one you're resample
matrix m2 = @resample(m1,0,30)
Imitation
Re: Resample
Postby Imitation » Wed Mar 25, 2015 1:38 am
Thanks for your prompt reply EViews Gareth.
I've tried the code with new matrix m2 but know it saves only one resampled sample, so that there is only one column of the data. I wonder what I'm doing wrong?
Re: Resample
Postby EViews Gareth » Wed Mar 25, 2015 10:25 am
You have to save it into a different matrix each time.
Imitation
Re: Resample
Postby Imitation » Wed Mar 25, 2015 4:42 pm
So, it's impossible to have all resampled samples in one matrix at once and I have to do it for 1000 iterations and the loop should contain all 1000 matrices. How can I group all matrices obtained then, because I have to transfer this data into excel (hope this procedure will work at once)
Re: Resample
Postby EViews Gareth » Wed Mar 25, 2015 4:51 pm
Use the matplace, or the vcat function to merge the matrices into a bigger one
