Corrected AIC / BIC
diggetybo
Corrected AIC / BIC
Postby diggetybo » Sun Mar 08, 2015 5:40 pm
In eviews 6, when estimating an AR/MA process is the AIC output automatically corrected to compensate, or is it the normal AIC?
If it's not built into the output, is there a relevant code to cut the procedure down to size for corrected AIC or BIC? I didn't think I saw this listed in the command list.
Re: Corrected AIC / BIC
Postby EViews Gareth » Sun Mar 08, 2015 7:49 pm
To which correction are you referring?
diggetybo
Postby diggetybo » Sun Mar 08, 2015 9:14 pm
I meant the alternate AIC for ARIMA processes. I believe it is a useful supplement to eviews view ARMA structure feature, when determining ARIMA orders.
The exact criterion would be:
I wasn't sure if either of these were built in, or if there was a line of code to view it in a scalar.
One could crunch the numbers manually without too much trouble, but while one modifies a model, the p's, q's and k's could be different every time, computing this by hand has some efficiency drawbacks.
Postby EViews Gareth » Mon Mar 09, 2015 12:10 am
No, that correction is not made, although when calculating the standard AIC and BIC, p and q are included in k.
