TAR based on Enders and Granger (1998)
chinxmint
Postby chinxmint » Thu Feb 05, 2015 8:42 pm
Hi, does anyone know if i can do TAR as mentioned in Enders and Granger (1998) on eviews.
The dependent variable is PriceA and independent variable is PriceB. i have done the Engle-Granger Cointergation and now i need codes to do a threshold autoregression.
Thank you
trubador
Did you use forum search?
Re: TAR based on Enders and Granger (1998)
Postby trubador » Fri Feb 06, 2015 12:55 am
That is for unit root test, if I recall correctly. As for implementation of TAR model within the context of cointegration, you may use Cointegration and Threshold Adjustment add-in.
