is there a way to write an EViews program which would enable to fetch from and write to a MySql workbench database?
Fetch (write) data from (to) MySql workbench
Re: Fetch (write) data from (to) MySql workbench
EViews can read from and write to MySQL using their ODBC driver.
You'll have to install the MySQL ODBC driver:
http://dev.mysql.com/downloads/connector/odbc/
Then create an ODBC DSN on your machine:
http://forums.eviews.com/viewtopic.php? ... mysql#p132
Then to read in data:
http://forums.eviews.com/viewtopic.php?f=3&t=28
Or write data:
http://forums.eviews.com/viewtopic.php?f=3&t=29
Or write data:
Another related post regarding MySQL directly:
http://forums.eviews.com/viewtopic.php? ... sql#p17568
How would the syntax look like between wfopen(type=odbc) and "select ..." in case I would like to connect to a server with a database requiring user id and password?
If you save the DSN as a File DSN, you can edit the DSN file (just a simple text file) to store the username and password. This way it's not so easily visible in any command you publish. Here's how to do that:
http://forums.eviews.com/viewtopic.php? ... 300&p=7745
You could also put it into the wfopen command link this:
The actual labels here (uid, pwd, database, etc.) may be different with different odbc drivers. You'll have to experiment with your ODBC driver to see what works for MySQL.
wfopen(type=odbc) dsn=MYDSN;uid=USERNAME;pwd=PASSWORD;database=MYDATABASE "select * from tablename" @freq a @id @date(datecol) @smpl @allSteve
Many thanks Steve!
Inittially it didn't work cause I used a 32-Bit connection config, after I reinstalled the necessary 64-Bit driver it worked perfectly!
No problem.
Yeah I should've mentioned that. 64-bit EViews will require 64-bit ODBC, while 32-bit EViews will require 32-bit ODBC. For some reason, even though the ODBC drivers are technically COM objects, you can't use them cross-bit.
