Eviews 8.1 Crashing on Help
econmiller
I can't seem to pull up any references in 8.1 via the help menu. The program hangs terminally or flat out crashes. Have 64 bit version, build Jan 12, 2015.
Re: Eviews 8.1 Crashing on Help
You mean you can't launch any PDFs?
econmiller
Correct. Nor can I launch the F1 help function. More of a nuisance than anything.
If you navigate to the EViews installation directory (usually c:\program files\eviews
, do you see a folder called Docs? If so, does it have PDFs inside it? If so, can you open them outside of EViews?
Are you running on Windows 8?
