Limitation to Iteration?
fmgoto
Postby fmgoto » Thu Jul 23, 2009 2:23 pm
Are there limitations to the number of iterations Eviews runs before haulting?
Eviews simply stops working for some erason I dont know. I suspect, for example, that tables do not support more than one million rows. Is that so?
Are there other restrictions?
Thank You, Fabio
Re: Limitation to Iteration?
Postby startz » Thu Jul 23, 2009 2:57 pm
You can set an iteration limit under the options for a particular estimate or the global options. I believe the default is 500.
Postby EViews Gareth » Thu Jul 23, 2009 3:07 pm
I don't believe there are any limits.
If EViews is crashing, you should probably email us at support@eviews.com, along with the program and workfile.
