multicollinearity concerns panel data across section or with
Re: multicollinearity concerns panel data across section or
Postby startz » Thu Nov 13, 2014 9:43 am
I misunderstood. Using a lagged dependent variable may be okay, but how do you know that it eliminates serial correlation?
Wouter van der Stee
Postby Wouter van der Stee » Thu Nov 13, 2014 9:46 am
Durbin Watson, or is that not a valid test if a lagged independent variable in included on teh right hand side? If so, is Durbin Watson a valid test for ar(1) included?
Postby startz » Thu Nov 13, 2014 9:51 am
Durbin-Watson is not a valid test in this circumstance. Use the Breusch-Godfrey test under View/Residual Diagnostics/Serial Correlation and set to 1 lag
Wouter van der Stee
Postby Wouter van der Stee » Thu Nov 13, 2014 9:59 am
That's not possible when running a GARCH(1,1) model. I use Eviews 7. The only test available is the ARCH LM test under this window...
Postby startz » Thu Nov 13, 2014 11:10 am
I'm not sure what to suggest as a work around, as the DW can be wildly off in this circumstance. My guess is that you should stick with using AR(1).
Wouter van der Stee
Postby Wouter van der Stee » Fri Nov 14, 2014 1:27 am
Startz,
Thank you very much for your time! Helped me a lot.
Wouter
