monte carlo simulation basics
hello everyone
my research is about evaluating mutual funds,, i use two kind of mutual funds ,, i want to use monte carlo simulation for risk ,, and i don't have any i idea about it ,,,i need help in steps or if any one could guide me to books or anything can help with it ,,, i am using Eviews 7
thank you ,,, and i will appreciate your help
CharlieEVIEWS
Re: monte carlo simulation basics
I recall thinking that this was an extremely simple exposition:
https://ideas.repec.org/c/ega/comcod/201101.html
And there are other threads on the forum:
http://forums.eviews.com/viewtopic.php?f=5&t=2192
I thought startz had a nice minimal working example which he had posted, but I must have been wrong/or I just can't find it now.
Thank you charlie for your helpful files .I really appreciate your help ....but the problem is I don't now anything about simulation or where should I start !? Do you know any guide books or websites for beginner users
Thank you
Thank you
This might help a little.
http://forums.eviews.com/viewtopic.php? ... rlo#p30150
CharlieEVIEWS
This is exactly what I was thinking of: I knew I had seen it somewhere!
great thanks .... how could i know more about simulation ? and for what we use it? is it for forecasting the risk?
In overly simplistic terms, you can think of simulation as the computer generation of artificial data, which can be used for many many purposes. Of course, Risk Management is (and should be) intensely involved in the subject, but it is not restricted to this field only. Professor Carol Alexander's four volume textbook on Market Risk Analysis might be helpful in this regard: http://www.carolalexander.org/mra.html
I am sure you have already did a Google search on the subject and read through the materials like this one:
http://en.wikipedia.org/wiki/Monte_Carlo_method
Below is the EViews code of Monte Carlo experiment to approximate the value of Pi:
!nobs = 30000 'number of observations
wfcreate u !nobs 'open a workfile
series x0 = @rnd 'x-axis of the circle
series y0 = @sqrt(1-x0^2) 'y-axis of the circle
series y1 'blank series to hold the random numbers to be generated
group gr.add x0 y1 y0 'group all the series
graph chart.scat gr 'draw a scatter plot
chart.setelem(1) symsize(1) 'use small symbol size for y1
chart.setupdate(m) 'manually update the chart
show chart
'Monte carlo simulation of Pi value
mode quiet
!count = 0
for !i=1 to !nobs
y1(!i) = @rnd
x0(!i) = @rnd
y0(!i) = @sqrt(1-x0(!i)^2)
if y1(!i)^2 + x0(!i)^2 <=1 then
!count = !count+1 'count the number of points inside the circle
endif
if @mod(!i,1000)=0 then
chart.update 'update the chart every other 1000 simulated points
endif
statusline !i of !nobs
'calculate the pi value
scalar pi = 4*!count/!nobs
oh thank you very much Trubador really helpful and that what i need,,,
so that code could i use it for my data or should i make new code suite my data ,,, i mean i have two kind of mutual funds and two kind of indexes by use 139 observations i want to calculate the Value at risk by using Monte carlo simulation to see which better, so how could apply it? how could i use simulation with it? and the four volume textbook for Professor Carol Alexander would help me ?
No, you cannot use the code for such purposes. It only demonstrates one of the many uses of monte carlo simulation.
I also suggest the chapters 9,10,11,14 and15 of http://eu.wiley.com/WileyCDA/WileyTitle ... 69039.html
All of these sources will be helpful.
thank you trubador i really appreciate your help ,,,
i just have one more question :? is there any book show the technique or steps for how to apply simulation and value at risk on eviews ?
thank you
thank you
I cannot recall such a specific book at the moment, but Carol Alexander's books include EViews examples. You do not have to worry about the EViews implementation, since most of the models are very easy (if not the easiest) to carry out in EViews. You'd better off focusing on the theory and getting familiar with the relevant concepts.
thank you all for your help ,,,i really appreciate your support
You might want to look at Foundations and Trends in Econometrics, Vol 5
Monte Carlo Simulation for Econometricians
by Jan F. Kiviet
by Jan F. Kiviet
thank you startz ,,, :)
Users browsing this forum: redversjones and 2 guests
