I am running following program from a book.
Can you kindly suggest me how to run and solve this problem?
workfile monte u100
!series=5
! draws=100
vector(!draws)montevec=0
--- I had an error message in this place/ !draws is not defined.
for !n=1 to !draws --- this also has some problem.
smpl 1 !series
series x=2+2*nrd
series y=x^2
montevec(!n)=@mean(x)/@mean(y)
series momentser=0
mtos(montevec, momentser)
thank you very much!
Vector and MonteCarlo Simulation
Re: Vector and MonteCarlo Simulation
You appear to have a space between ! and draws in line 3. this makes !draws undefined.
! draws=100
!draws=100
Thank you for your comment. But it doesn't work. !draws=100, but when I typed
vector(!draws)montvevec=0, it says still undefined. Can you correct me what I was wrong?
Thank you very much!
Are you running in a program?
I'm just running the program at the command space of Eviews.
Did you run my program and find no problem? Can you show your results/ Or, I might did a wrong way. I am not good at programming.
You need to run as a program, not a series of commands.
I will try and let you know. Thank you!
It worked very good! Thank you very much! By the way, do I need to always run a program by using batch mode?
