Different ways to check for NA
What is the difference between @isna(a) and a=na in if statements? Which one would be better or faster? The result is the same.
Re: Different ways to check for NA
They're essentially the same.
The former is a bit easier to read when using expressions, as in the admittedly artificial example
versus
(log(y)*(exp(x)=37))=naCode: Select all
@isna(log(y)*(exp(x)=37))-
And you can use @isna inside other functions
