Panel HP filtering
felix.casares
Re: Panel HP filtering
Postby felix.casares » Mon Aug 18, 2014 12:20 pm
where? i was copy exactly
copy(smpl={%strsmpl}) ln_gdp_sa nonpanel\ @src @date @dest @date
Postby EViews Gareth » Mon Aug 18, 2014 12:21 pm
That looks ok
felix.casares
Postby felix.casares » Mon Aug 18, 2014 12:59 pm
when i execute for !i=1 to !ncross, appear this message: flow of control statement executed from the command line. maybe that ´s the reason for the error before, but in dont kwno how fixed
Postby EViews Gareth » Mon Aug 18, 2014 1:09 pm
You need to run it in an EViews program (File->New Program)
mitraolia
Postby mitraolia » Sun Sep 25, 2016 1:22 am
hello
my data is in panel format and i wanted to filtered them with hp filter. then i entered them in eviwes in undated format (not panel foemat), in this way eviwes allowed me to use hp filter. and once again i use hp filter one by one for each country sepratly in dated format(not panel fomat). the problem is that, the outcomes are different in this two way, which of these ways are reliable???? :shock:
thanks for your accountability
Postby EViews Gareth » Sun Sep 25, 2016 3:28 pm
If you bring it in as undated, EViews won't know where one cross-sections ends and the next begins. As such it will use information in one cross-section when computing the filter for another.
