NLLS estimation
Chris
NLLS estimation
Postby Chris » Wed Jul 01, 2009 2:47 am
I am quite new to EViews and I desire to estimate a model that includes a hyperbolic tangent with NLLS. Equation is of the form Yt= c1+c2*Xt +tanh((Xt+1-Xt)*(c3*Xt-c4*Pt)). A syntax error appears when implemented. What are the proper steps for estimating such parameters? Should I provide some starting values from a restrictive case? Would another method like maximum likelihood be more appropriate?
Your help will be very much appreciated!
Chris
trubador
Did you use forum search?
Re: NLLS estimation
Postby trubador » Wed Jul 01, 2009 5:16 am
You can enter the following into the equation editor:
y= c(1) + c(2)*x + (@exp(2*((x(1)-x)*(c(3)*x-c(4)*p))-1)/@exp(2*((x(1)-x)*(c(3)*x-c(4)*p))+1))
And yes, supplying initial values might be helpful in terms of convergence. However, you should be careful in using the tanh(x) function, since it takes values between -1 and +1 and saturates quickly (e.g. |x|>3).
Chris
Re: NLLS estimation
Postby Chris » Thu Jul 02, 2009 2:29 am
Thanks a lot ! I just have to restrict some parameters and I'm done. Already saw a topic in this concern.
All my best,
Chris
