Threshold determination
hsmellin
Postby hsmellin » Sat Feb 15, 2014 5:26 am
i am looking to estimate a TAR model and to search for the threshold value of the dependent variable using the Chan (1993) methodology*.
I try the following code:
vector(67) ssr_result
for !i=1 to 67
genr h_!i=0
genr tau_!i=@elem(y, !i)
smpl 2 67 if y(-1)>=tau_!i
genr h_!i=1
smpl 2 67
equation tar_{!i}.ls d(y)=c(1)*h_!i*((y(-1)-tau_!i))+c(2)*(1-h_!i)*((y(-1)-tau_!i))+c(3)*d(y(-1))
scalar ssr_{!i}=@ssr
ssr_result(!i)=@ssr
(I have sorted and trimmed the observations before running this code). However, i get an error message for "genr tau ...." i think there may be more errors with this code; i am very new to programming so apologies if the whole code is incorrect!
*Chan, K. S. (1993), "Consistency and Limiting Distribution of the Least Squares Estimator of a Threshold Autoregressive Model," The Annals of Statistics, 21, 520-533
ninjagirl
Re: Threshold determination
Postby ninjagirl » Thu Jul 17, 2014 7:01 am
Have you found the answer to your question? I am looking for that as well. Do help me out if you have found a solution.
I am trying to use the TARCOINT add-in
Regards,
Prarthana
ewa
Postby ewa » Mon Jan 05, 2015 1:40 am
The add-in is very helpful. I managed to get all the estimates I wanted. Just wanted to make sure, the output does not provide information criteria results. Is there any way to get them to compare models?
Best regards,
Ewa
trubador
Did you use forum search?
Postby trubador » Mon Jan 05, 2015 7:06 am
Lag-length selection already uses information criteria to decide the appropriate lag. I am not sure, but you may estimate the final model in light of the add-in's output and then compute/extract the information criteria ex-post for model comparison purposes.
