Is it possible conduct a rolling BDS on data in EViews? I have tried a few different loops but it doesn't seem to be working.
Any suggestions?
Rolling BDS test
Re: Rolling BDS test
Sure it is.
create u 1000
series y=@nrnd
!window = 50
!step = 20
for !i=1 to 100 step !step
smpl @first+!i-1 @first+!i+!window-1
y.bdstest(o=vec!i)
nextRe: Rolling BDS test
Hi Gareth,
Thanks for your reply. However the code seems to not work.
When I input the line "for !i=1 to 100 step !step", an error message appears saying 'flow of control statement executed from the command list".
And then after I input the next line I get "error in sample !I is not defined".
Can you help with this or tell me what the issue is?
Many thanks
Andrew
Many thanks
Andrew
I just used Gareth's program (copied from the post and pasted not retyped) and it worked fine.
I use EV8
I use EV8
Hi Terry,
I have done the same but I still get an error message. I also use EV8. I have named the series 'y'. Does it matter how many observations there are? I am also using a clean Eviews file.
I am missing something really stupid.
Andrew
Andrew
Why did you rename the series? It's already called y or did you type 'y' instead of y?
What i meant was that I have named my series y, and then copied and pasted the code and I get the error message "flow of control statement executed from the command line".
Thanks guys, I have got it to work.
One more question: I have over 10,000 observations and want a window size of 500 that rolls 10 observations at a time, thus the number of outputs will be quite large. Is there anyway to have the outputs put in a matrix one after another?
Thanks again,
Andrew
Thanks again,
Andrew
You can use the colplace function to put the column of results into a matrix.
Thanks for your reply Gareth.
So far I have the following code for a 5079 observation sample running the BDS test for a 500 observation window rolling forward 20 observations at a time;
create u 5079
series y=@nrnd
!window = 500
!step = 20
for !i=1 to 5079 step !step
y.bdstest(o=vec!i)
I have tried to input the colplace function but it doesn't seem to work. Can you help with this?
Also, is it possible for the rolling bds test to provide the p-values/z-statistics as well? What do you need to input?
Thanks again and I look forward to your reply.
create u 5079
series y=@nrnd
!window = 500
!step = 20
y.bdstest(o=vec!i)
How did you use colplace?
Have you looked up the .bdstest procedure in the object reference?
I use the following code and it works great! However when I include in the bracket e=2, I get a zero output each time. Is there anyway of storing the bootrapped p-values, or the ordinary p-values? (I can't see an option for this in the object reference).
create u 5079
series y=@nrnd
!window = 500
!step = 20
y.bdstest(o=vec!i, b=1000, d=10, m=s)
Also I am confused about how to use colplace - can you help?
create u 5079
series y=@nrnd
!window = 500
!step = 20
