Panel or Pool?
Re: Panel or Pool?
To estimate Fully Modified OLS and Dynamic OLS individual cross section country estimation pedroni's approach article link- http://web.williams.edu/Economics/wp/pe ... asing.pdf- could you please help me how to estimate the same for each countries.
Thanks regards
Thanks regards
Re: Panel or Pool?
EViews 8 panel structured workfiles allow you to estimate these models.
Re: Panel or Pool?
Could you please explain the step o estimation using structural panel, i am unable to do it..
Re: Panel or Pool?
Hi Gareth,
When writing about advantages and disadvantages of using Pool or Panel workpages, you state that an advantage of the panel workpage is that "any lags/leads will never cross seams (the last observation for one cross-section will never be included in the lags of the next cross-section)".
Can you please elaborate on this point? Will this happen if you work in a pool workfile?
EViews Gareth wrote:Panel or Pool?
There is no right or wrong answer when deciding whether to use a panel or a pool workfile structure when working with panel data in EViews. However, here are some bullet points that trade off one against the other.
- Pool workfiles can become complicated and messy when you have many cross-sections.
Since you need a series per cross-section per variable, as soon as you have many cross-sections, your workfile can grow very large. In a panel, you only have one series per variable no matter how many cross-sections you have.- Panel workfiles can be tricky to use if you want to deal with large sub-sets of cross-sections.
In the pool workfile, you can create new pool objects for each set of cross-sections you want to deal with. Defining those pool objects is simply a case of listing the cross-section IDs you want to use. In a panel workfile, you need to use sample if statements to define which cross-sections you want to deal with, which can become quite cumbersome:Code: Select all
smpl if country="USA" or country="FRA" or country="JPN" or country="CAN" or country="UK" etc.....
- Pool workfiles make it easy to perform cross-section, cross-variable analysis. Panels do not
In a pool workfile it is easy to group different variables for different cross-sections. For example, cointegration between Unemployment in France and GDP in the UK can be performed by simply opening those two series as a group in the pool workfile. In a panel workfile it is almost impossible to do this.- Panel estimation has more estimation options and techniques available
As well as specialised panel-estimation techniques for least-squares, two-stage least squares and GMM (including dynamic panel data estimation), most of the standard non-panel estimation methods (probit, liml, quantile regression, etc...) are available on the stacked data. Further any lags/leads will never cross seams (the last observation for one cross-section will never be included in the lags of the next cross-section).- Pool estimation lets you calculate cross-section specific coefficients
The pool object lets you specify cross-section specific coefficients in least squares estimation. The panel estimator does not allow this (other than cross-section specific constants, i.e. fixed effects).- The panel workfile lets you generate cross-section or period statistics easily using the @statsby functions
For example if you want to create a series containing by-cross-section means (i.e. the mean of a variable per cross-section) of a variable, Y, you could use the following:Code: Select all
series cxmeans = @meansby(Y, @crossid)
where @crossid is a keyword meaning cross-section identifiers. To do the same for periods:Code: Select all
series pxmeans = @meansby(Y, @obsid)
where @obsid is a keyword meaning date/time identifiers.
This can be done in a pool workfile by using the pool object's generate procedure.- Panel equations have built in forecasting. Pool objects do not - model objects must be used instead
Feel free to post any other issues with pools or panels below.
Re: Panel or Pool?
That point is just meant to say that a wider set of non-panel specific estimation methods are available in a panel workfile.
You cannot, for example, estimate a VAR or a probit using a pool. You can in a panel, although the methods use will be the non-panel versions.
Re: Panel or Pool?
As to EViews 8 panel cointegration...the manual has step-by-step instructions and examples.
Re: Panel or Pool?
Is there any limit for the cross dimension? When try to estimate a fixed effect model (770 cross section x 7 time periods) Eviews reply an error message: "Matrix size error: too many parameters for default coefficient vector"
Pedro
Pedro
Re: Panel or Pool?
Change the coefficient vector to something else. It is an option on the estimation dialog.
Re: Panel or Pool?
Thank you for your explanation about Panel and Pooled. I would like to ask some question. How can I check multicollinearity in Pooled Least Square.
In Eviews 6, I click Quick --> Group Statistics --> Correlations, Then I type equation in Series List, for example, logfdi? logfdi?(-1) loggdp? logwage?
After that, Error message said that logfdi? logfdi?(-1) loggdp? logwage? is not defined.
So, I don't know how to check multicollinearity. Could you please help me?
Thank you in advance.
Re: Panel or Pool?
hi,
Id like to use a panel regression, but have a couple questions
1) when i estimate an equation I get the error '--Insufficient number of observations in "EQUATION EQ1.LS(CX=F) PB C EPS SECTOR"--. However, when I just use eq1.ls(cx=f) PB C EPS (i.e without 'sector' it works fine). variable sector has the same number of observations, so I can't figure out what happening
2) im ultimately trying to control for the variable 'sector', which is a category variable with 11 categories. Is there an easy way to do this with a panel? It is also already in stacked format.
Re: Panel or Pool?
Check to see if the sector variable has NAs.
Look at the @expand command for controlling for multiple sectors.
Re: Panel or Pool?
Sector does not, PB has some NAs but the equation works fine with just 'pb' and 'eps"
Re: Panel or Pool?
Workfile received...
Your sector variable contains no numerical data, thus every observation is an NA.
You'll have to convert it into a numerical variable, or create dummy variables using @expand as Startz suggested.
Users browsing this forum: No registered users and 9 guests
