The equation object returns the sample that was set at the time the equation was run, i.e., eq.@smpl. However, due to missing observations, for example, the sample may be adjusted and is reported in the output. Is it possible to programmatically extract the adjusted sample?
Thanks.
Equation sample after adjustments
Re: Equation sample after adjustments
ls y c x
series kludgeDummy = not @isna(resid)
sample kludgeSample if klugeDummy
The general idea is correct, though I would modify the recommendation slightly to use explicit equation names and the makeresid proc. The resid series is often modified and I wouldn't want someone to think that they can always extract the sample from what's currently in resid.
etc.
equation eq1.ls y c x
eq1.makeresid eq1residWho is online
