When to use VAR/VECM
hana88
Postby hana88 » Tue May 13, 2014 11:18 pm
Hi All,
I am a bit confused on when to use VAR or VECM. Is this decision dependent on the unit root test? Let say I have dependent variable Y and independent variable X where each is stationary at I(1), which model should I use?
And when is the right time to use Toda Yamamoto?
Thanks in advance.
Regards,
Confused.
NicolasR
Re: When to use VAR/VECM
Postby NicolasR » Fri May 16, 2014 10:13 am
You should use VECM if 1) your variables are nonstationary and 2) you find a common trend between the variables (cointegration). If your variables are nonstationary and you transform them to became stationary (diferences or subtracting trends) without doing a cointegration test you might be omitting a relevant variable, the cointegration relationship. So, if you don´t find cointegration in your test you can estimate a VAR with the stationary variables.
Best regards.
hana88
Postby hana88 » Tue May 20, 2014 5:59 am
Now I get. thanks much!
