HI guys,
I am using Eviews 7.2
suppose I have three time series, I would like to get a list of series which have more than 10 in any given year, maybe in the form of a string object.
how would I go about doing it ?
for example:
2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011
series A 4 9 8 7 3 7 1 2 5 8 7 3
Series B 2 10 8 11 10 5 9 11 9 5 8 9
Series C 1 9 7 6 8 9 2 1 5 4 11 4
I should get series B and C in my list.
I think it should really straight forward but I have had a hard time coming up with a solution.
any help would be appreciated.
build a list of series which fits a criteria
Re: build a list of series which fits a criteria
I'm not sure what you're asking. It isn't clear how B and C get into your list. As far as I can see, there isn't a single year in which they both have a value greater than 10. Perhaps you mean they have 10 observations?
hi Gareth,
series A, B and C are three time series between year 2000 and 2011. i would like to include any series which have greater than 10 in numeric value into a list so i can undergo further data manipulation.
in the example below, i can see
series B is greater 10 in the year 2003 and 2007
series C is greater than 10 in the year 2010
series 2000 2001 2002 2003 2004 2005 2006 2007 2008 2009 2010 2011
Many thanks,
Many thanks,
hi Gareth ,
i can see how confusion may arise, i cannot get the data to line up properly, the top row is suppose to be year.
please refer to the attached excel file for the time series.
- example .xlsx
- (8.82 KiB) Downloaded 280 times
Ah, my confusion was from your use of "greater than 10 in any given year". I think you want "greater than 10 in any year". Or, really, you just want to check whether the maximum of the series is greater than 10.
%baselist = "a b cc dd ee ff"
%result = ""
for %j {%baselist}
if @max({%j})>10 then
%result = %result + " " + %j
endif
