out of memory
shm83
out of memory
Postby shm83 » Tue Apr 08, 2014 8:16 am
I have been searching through the forum but I did not find it.
While running a program, it gets out of memory. It generates 4000 matrixes of 365*365 data, and 4000 of 365*5. Is there a way so I can truncate those matrixes/data to 4 or 6 decimals? I think that would work the problem out.
Thank you in advance!
Re: out of memory
Postby EViews Gareth » Tue Apr 08, 2014 8:19 am
There is not.
If you're not using EViews 8 64bit, you should try that.
shm83
Re: out of memory
Postby shm83 » Tue Apr 08, 2014 8:25 am
:cry: :cry:
thanks for the prompt answer, i will ask if we can have it (the 64 bit one)
Re: out of memory
Postby EViews Gareth » Tue Apr 08, 2014 8:40 am
If you already have EViews 8 32bit version, you can download and install the 64bit version for free, without any need to contact us - your existing serial number should work.
Re: out of memory
Postby startz » Tue Apr 08, 2014 10:26 am
Note that you are generating data that takes up approximately 4GB. So unless you have significantly more than 4GB memory you are going to have a problem. Do you need all 4,000 matrices at once, or can you delete some as you go?
