Call EViews 8 (64 bit) from Matalb 2013a (64 bit)
Re: Call EViews 8 (64 bit) from Matalb 2013a (64 bit)
Dear Steve:
Yes, I did it every time.
Ya, it is very strange....
I specified "EViews.Manager8" as the ProgID.
EVIEWS 7 ejected may be because I firstly tested the script by Matlab 2013a (32bit).
It never shown again.
Hi there,
Sorry to add to this, but I am having a very similar problem.
I am trying to call Eviews 8 (64bit, enterprise edition, updated with latest patch) from Matlab R2009b (64bit). A COM object is created, but it is empty. I followed the recommendations in this conversation (e.g. REGCOMPONENTS), but it still doesn't work.
When I list the programs Matlab has access to, Eviews is not among them. Using Excel from Matlab works fine.
Best
Best
Ok, here are a few things to check:
1. Make sure both EViews and MATLAB are both physically running on the same machine. No App-V installations, no virtual machines, no Citrix.
2. Make sure EViews is installed locally and is not running from a network file share.
3. Open EViews 8 64-bit, then type in command REGCOMPONENTS into the EViews command window and hit Enter. Click "Yes (All)" to re-register everything. Wait for the "All registrations completed successfully" message to appear. Re-run REGCOMPONENTS and verify that next to "COM Automation & OLE" it says "Registered". Click No to close the dialog, then quit EViews.
4. See if you can use/control EViews COM from Excel. Startup Excel with a blank worksheet, press ALT-F11 to display the developer GUI, go to Tools->Add References... and make sure "EViews 8.0 Type Library" is checked. Close the dialog, then create a new VBA subroutine named "test" in any available module. Here's what "test" should look like:
Then click the "Play" or "Run" button to run the code. Verify that a new instance of EViews 8 64-bit appears.
5. If VBA worked fine, you should be able to use EViews COM from MATLAB as well. I typed in the following commands into my copy of MATLAB 7.9.0 R2009b 64-bit:
and EViews 8 appeared just fine.
If you still get an error, it would be helpful to see the exact error you're seeing from MATLAB (or Excel)...
Public Sub test()
'first add reference to "EViews 8.0 Type Library"
Dim mgr As New EViews.Manager
Dim app As EViews.Application
Set app = mgr.GetApplication(NewInstance)
app.Show
Set app = Nothing
Set mgr = Nothing
End Sub
>> clear all
>> mgr = actxserver('EViews.Manager.8')
mgr =
COM.EViews_Manager_8
>> app = mgr.GetApplication(0)
app =
Interface.EViews_8.0_Type_Library.IApplication
>> app.Show()
Hi Steve,
many thanks for this. I am afraid it still doesn't work.
All the previous steps worked as required, but no joy when I try it from Matlab, see the error below.
Btw, when running Eviews (REGCOMPONENTS) and later Matlab, I launched both as "run as administrator". Would be grateful for further advice.
>> clear all
>> mgr = actxserver('Eviews.Manager.8')
mgr =
COM.Eviews_Manager_8
??? No appropriate method, property, or field GetApplication for class COM.Eviews_Manager_8.-
Ok, let's try this:
1. Open a DOS command window (with admin rights), then go to the "EViews 8" subdirectory under "Program Files" (not "Program Files (x86)").
2. Type in the following command:
3. Wait for a success message.
Close the success dialog and then restart MATLAB and try to get an EViews Manager and Application object as before.
Does this work?
regsvr32 EViewsMgr.dllClose the success dialog and then restart MATLAB and try to get an EViews Manager and Application object as before.
Does this work?
Hi Steve,
many thanks for looking into this. No success so far, though, I am afraid, when I try the steps you suggested.
Not sure what to do.
Well I'm at a loss too. If you can use EViews 8 64-bit COM Automation from Office (32-bit or 64-bit?), I don't see why MATLAB would have a problem.
The original poster had issues because he had removed his EViews 32-bit and only had EViews 64-bit installed. I wonder if you try installing EViews 8 32-bit onto the same machine if that will resolve your problem. You can have both versions running on the same machine using the same serial number...
Ok I have a new idea you can try:
Open another DOS command window (with Admin rights) and go to the EViews 8 subdirectory again. If you're running EViews 8 64-bit, you will need to switch to the "x86" folder (so you should now be in "C:\Program Files\EViews 8\x86"). Now type in the following:
(this will unregister the 32-bit version of our EViews.Manager class) Click OK to close the success dialog.
Now switch back to the main "EViews 8" subdirectory, then rename the "x86" folder like this:
Then re-register EViews 8 by typing in this:
(You might get an error message about not finding a few items to register. Just click OK to close the dialog.)
Finally, restart MATLAB, perform a "clear all", then see if you can get EViews COM working now...
regsvr32 /u EViewsMgr.dllNow switch back to the main "EViews 8" subdirectory, then rename the "x86" folder like this:
rename x86 x86_hideCode: Select all
EViews8_x64 /regcomFinally, restart MATLAB, perform a "clear all", then see if you can get EViews COM working now...
Have you gotten a chance to try my last suggestion? Please let me know if it worked or not...
Steve,
Sorry about the delay in responding. Many thanks for this. I am afraid it still doesn't work.
I may try uninstalling Eviews and Matlab and then re-installing.
Thanks again!
Thanks again!
Hmm. I was pretty sure that last bit was going to work.
In any case, a few changes have been made to EViews 8 registration in the latest patch. If you get a chance, try downloading the latest patch for EViews 8 64-bit, install it, then try your MATLAB test again.
See if that helps...
Hey,
I have the same issue. I am using Eviews 8 and matlab 2013a, both 32bit, windows 7. I get the exact same error as the OP, and have tried all your suggestions. Is there anything else I could do to make this work?
Ok, let's try something different.
First, try to write a short VB.NET or C# Console program to control EViews use COM automation. Our white paper discusses how to do this:
http://www.eviews.com/download/whitepap ... mation.pdf (you'll have to change the reference to be "EViews 8.0 Type Library")
Compile this program as a small EXE somewhere and make sure it works if you just double-click the EXE. Make sure it is the correct version of EViews that is being used (if you have older versions of EViews installed as well).
Next, try launching this EXE from your MATLAB program. Does this work?
Ok, I was able to download MATLAB 2013a myself (trial version) and was able to reproduce the problem. It definitely seems like it's an issue with MATLAB. But in any case, if I find a workaround, I'll let you all know...
