The addin selec arima is not correct because it doesn't keep the same size fixed. If you start with an ARMA(7,7) your size is 8 to T and when you estimate an ARMA(6,6) the new estimation size is 7 to T instead of the previous one. Therefore the two AIC or SIC are not comparable
Best regards
Pedro Valls
Selec arima add in
Re: Selec arima add in
Actually, the add-in uses the same, shortest, sample to estimate each of the different models.
