How I choose the result of Unit Root Test ?
490610362
Postby 490610362 » Sat Feb 01, 2014 9:04 am
Hello
I tested Unit root with ADF at Level I(0)
(X)
With trend and Intercept > Stationary
With intercept > Stationary
None > Non-Stationary
What the result that i should choose ?
If it stationary at Level, can i do johansen's cointegration test with this variable? (Other variables (Y,Z) are stationary at 1st diff I(1))
Thank you,
Gaya
Re: How I choose the result of Unit Root Test ?
Postby Gaya » Tue Feb 11, 2014 9:04 am
I am not a expert in econometrics. However, best way might be to use other methods like Phillips-Perron (PP) or Kwiatkowski–Phillips–Schmidt–Shin (KPSS). I have seen in some articles used all 3 methods (i.e. ADF, PP, KPSS). Most probably you may conclude that at I(0) variable is stationary.
