Object exists in database
javiersan
Postby javiersan » Tue Jun 09, 2009 9:49 am
is there a function like @isobject() that allows to know whether an object exists in a database without having to fetch it?
Thanks,
Javier
Re: Object exists in database
Postby EViews Gareth » Tue Jun 09, 2009 9:52 am
Unfortunately not.
Joe
Postby Joe » Tue Aug 02, 2011 1:13 am
Hi Janvier,
The following example might help your question. My databse name is XYZ which stores series with name like EST.GGINTR, EST.IRL etc. but some series do not exist in my database. So I use a combination of @wlookup and @wintersect to serve like @isobject. An example of the code is below.
!row=1 table(!row,100) results 'create a table to store the result %object_list = @wlookup("XYZ::*") 'get a full list of object names from the XYZ databases for %country EST ISL ISR KOR LUX SVN SVK for %variable GGINTR IRL GDP IRS GNFL 'a list of variable of interest %my_string_{!row} = @wintersect(%country + "." + %variable, %object_list) 'check any intersect between my variable of interest and the full list if %my_string_{!row} <> "" then setcell(results, 1,1,"exists outputs") table results(!row+1,1) = %my_string_{!row} + " exists" endif !row = !row + 1 next next
Hope this helps.
Joe
