Im trying to import the OECD STAN database, where the txt file starts as:
Cou|Var|ind|year|value|datanote
AUS|CPNK|0199|1970|680794818590|
AUS|CPNK|0199|1971|718765520049|
USA|WAGE|zzz5|2008|368303000000|p
USA|WAGE|zzz5|2009|332853000000|p
when importing this file i tried the command
wfopen(type=text) "..\data\stan_all\data.txt" custom="|" names=(country, variable, industry, time, data) types=(a,a, a, d, f).
However, the industry variable is read as a number (199) and not an industry code. the industry code zzz5 is recorded as na.
Question 1: what is the command for importing this type of text file?
Question 2: what is the code to untsack this file into a pooled workfile? will pageunstack variable country industry time work?
Hope you can help me with this
Sincerely
Importing txt data - unstacking
Re: Importing txt data - unstacking
Could you provide an example file?
Sure,
here is the file with two countries only, and with a different industry for each country.
- Data_2_countries.txt
- (68.39 KiB) Downloaded 321 times
Industry read as an alpha for me (up to date EViews
, using your exact code (with a file name change).
It looks like you have a 3D panel. You can't unstack it into a Pool, unless you're willing to contract two of the dimensions into one.
thats strange. Now im at home, using Eviews 7.2, and it will not read the industry information as an alpha. but Eviews 7.2 does not recognise the command types=(a,a, a, d,f), so my command now reads
wfopen(type=text) "..\data\stan_all\data_2_countries.txt" custom="|" names=(country, variable, industry, time, data)
At work i have Eviews 8. I will double check that im running the latest version tomorrow. I hope updating the software works.
Thanks for looking at this
- data_2_countries.WF1
- (88.25 KiB) Downloaded 241 times
The update worked,
I had the november version. updating it to dec 19 2013 worked.
