Hi everybody, my name is Namazbai and I hope you will be able to help me. I have a problem shown below:
I have to import data from Excel to Eviews using programming, so I use this way: File->New->Program and then I write coomand wfopen c:\Users\Namaz\Desctop\data.xlsx. But when I run program this code doesn't work, so I don't know what to do. In the Excel file there several columns with time series of GDP, CPI, etc. The data is quarterly. My general target is building a program, that will be able to import data from Excel file, check it for stationarity, seasonality and build ARMA/ARIMA's. But unfortunatly I couldn't even import data((( I'm sorry for this silly question, I work well with Eviews using interface, but I haven't experience in programming, please help me. Thanks!
Problems when importing data from Excel
Re: Problems when importing data from Excel
Could you define what you mean by "doesn't work"?
Fortunately it worked when I tried this function in Eviews 6, previous unsuccesfull attempt was on Eviews 3. But now I have another problem, so could you help Gareth, if it's possible. My trouble is again connected with importing data using command read.. I have Excel file with GDP, UNEMPLOYMENT, CPI and M1,M2 variables, so I must import this data to eviews workfile to start my research. This excel file is regularly renewing - I add new odservations, delete some series and add new series.
So, my trouble is that I can't make a code, that is able to import data dynamically, without correcting of read command. For example, I import 3 variables - GDP, CPI and Unemployment (100 observations). I create undated eviews workfile with 100 obs, then I type: read(a2,s="sheet3") "c:\path" 3 . After running programm this command qualitatively imports data, but when I expand my Excel file adding new variables and changing the size of sample I've to correct code, for example I add to Excel M1 and M2 aggregates, so I open the program and type read(a2,s="sheet3") "c:\path" 5 . How can I make a code, that is able to import data from Excel dynamically without my permanent corrections? Thank you, Gareth!
Read cannot do it. You'll need to use wfopen, or import (in EViews
Thank you very much!!! (Y)
