Slow matrix inverse
trubador
Did you use forum search?
Slow matrix inverse
Postby trubador » Fri Jan 03, 2014 12:50 pm
This is not a bug, but when the following code is run, EViews returns the answer after a long while (3 minutes in my case). I'd like to know if anything can be done to speed things up.
tic wfcreate u 100 matrix y = @mnrnd(2500,2500) matrix z = @inverse(y*@transpose(y)) scalar elapsed = @toc/60
Re: Slow matrix inverse
Postby startz » Fri Jan 03, 2014 1:35 pm
Just to chime in, in Matlab the same code takes 2 to 3 seconds. That's a very big difference.
Postby EViews Gareth » Fri Jan 03, 2014 5:32 pm
tic wfcreate u 100 matrix y = @mnrnd(2500,2500) matrix z = @inverse(@inner(y.@t)) scalar elapsed = @toc/60
trubador
Postby trubador » Sat Jan 04, 2014 4:32 am
Yes Gareth, thanks. It is much better (5x faster).
