Static data from Datastream
rousing
Postby rousing » Tue Dec 10, 2013 5:53 am
Is there a way to retrieve static data from Datastream either with copy, fetch or similar?
Thank you in advance for your assistance.
Best regards
Rasmus
Re: Static data from Datastream
Postby EViews Jason » Tue Dec 10, 2013 8:46 am
What type of static data do you wish to request? Can you give an example?
rousing
Postby rousing » Tue Dec 10, 2013 9:28 am
basically any data identified with static datatype, for instance the settlement date of an interest rate futures contract. Ticker: "ABB0618", settlement date identifier: "STDT".
Postby EViews Jason » Wed Dec 11, 2013 10:35 am
It is currently not supported. We are looking into adding the feature however. If the feature were to be added, how would you like the data appear in an EViews workfile (as a scalar, matrix, series, vector, alpha string, etc)? I cannot promise it will behave as you would like, but your input will be taken into consideration.
rousing
Postby rousing » Wed Dec 11, 2013 11:04 am
Hi Jason
Since the static data types normally contain either dates, scalars or strings it would probably be best if the function call returned a string.
In case several static identifier codes are allowed in one function call an svector would probably be preferred, in my view.
Thanks a lot for looking into this.
Best regards
Rasmus
rousing
Postby rousing » Mon Dec 22, 2014 1:44 am
Hi Jason
Another addition that also could be very helpful would be the ability to retrieve constituent lists directly from Datastream with the fetch command, for instance for the S&P500 index DS ticker: LS&PCOMP. Preferred output in this case would also be a svector.
Thanks in advance for looking into this.
Best regards
Rasmus
rousing
Postby rousing » Mon Mar 07, 2016 8:42 am
Hi Jason
I was just wondering if there are any news on retrieving static data fields and the content of constituent lists from Datastream.
Thanks in advance for your help.
Best regards
Rasmus
