Loop - foreach series
Jelena
Postby Jelena » Wed Dec 04, 2013 7:33 am
I want to standardize all variables in the following way:
series std_inflation= (inflation-@mean(inflation))/@stdev(inflation)
Is there any command, which can be used to do this foreach (and all) series I have in my workfile at once?
Thanks in advance!
Jelena
Re: Loop - foreach series
Postby EViews Gareth » Wed Dec 04, 2013 8:51 am
%list = @wlookup("*", "series") for %j {%list} series std_{%j}= ({%j}-@mean({%j}))/@stdev({%j}) next
Jelena
Postby Jelena » Wed Dec 04, 2013 10:10 am
thanks for your response!
I just started using Eviews...
When I use:
there is no error but I can not see any changes in the workfile.
After the next command:
for %j {%list}
Eviews shows following Error Message:
Flow of control statement executed from the command line
Then the next command:
gives the Error: %J is not a valitd string or scalar name.
What did you do wrong?
Thanks in advance!
Jelena
Postby EViews Gareth » Wed Dec 04, 2013 10:11 am
You have to make an EViews program (File->New Program)
Jelena
Postby Jelena » Wed Dec 04, 2013 10:37 am
Thank you! Now it works :)
