Impose coefficient restrictions in uncontrained VAR
jfgeli
Postby jfgeli » Mon Nov 11, 2013 11:52 am
Hi there,
I want to impose a linear restriction (lets say c(1) = 0) in one of the coefficients of an unrestricted VAR which I am estimating in a model. Is there a way to append (is that the command) the restriction inside the model and then estimate the coefficient? If so, could you give me a short example or let me know where in the documentation I can find an example?
Regards,
Fede
Re: Impose coefficient restrictions in uncontrained VAR
Postby EViews Gareth » Mon Nov 11, 2013 12:01 pm
The only way to do it is to convert your VAR into a system (proc->make system) and then impose the restrictions in the system. Unfortunately you'll lose all of the post-estimation views and procedures available to a VAR (such as impulse responses).
jfgeli
Postby jfgeli » Mon Nov 11, 2013 12:56 pm
I'll have to change the whole estimation strategy then...
Many thanks!
oth76
Postby oth76 » Tue Nov 12, 2013 3:03 am
Hi everybody,
Is it possible to constraint the system using a command line in a relative automated manner ?
After an estimation of unconstrained VAR, let's say var1, many coefficients appear to be non-significant. I want to re-estimate the system by imposing them to be null.
After, I guess this first command:
var1.makesystem(n=sys1)
what command should I use ?
Any simple example please ?
Thank you for your help.
Postby EViews Gareth » Tue Nov 12, 2013 3:24 am
No, there is no easy way to do that.
