Hi Gareth, I just had Eviews 8 installed. I understand that the new version can support panel causality test. But I can't find the commands. (I prefer the programming to the menu.) Could you please refer me to the commands in the online manual?
Linked with this, what are the facilities for testing the right lag for the panel causality test?
Many thanks.
Re: panel causality test
group.cause(dh)
So I stack cross section data into 2 series, make into a group and use the Cause command? I understand there are two methods for panel causality. One is dh. Then what is the other?
Same command without the dh option.
