Super add factors?
tbui
Super add factors?
Postby tbui » Wed Oct 23, 2013 1:14 pm
Hi gurus,
Is there any option or plan to adopt the use of super-addfactors in the sense like this:
- I want to impose a 1% increase in GDP by add factoring
- GDP is sum of C, I, G, NX, so the imposing 1% increase in GDP means imposing 1% increase in all of its components.
I think it's a tricky one if the model has layers of identities (i.e. C is another identity), however an option like that would be nice.
Thanks,
T
EViews Chris
Re: Super add factors?
Postby EViews Chris » Thu Oct 24, 2013 11:09 am
I'm afraid there's no inbuilt support for an operation like that.
I do see what you're getting at though - you would like the add factor adjustments to end up in equations that contain errors rather than on identities (which don't).
There's quite a few details that would have to be sorted out though. For example - what happens if the identity is non-linear (in which case increasing each input proportionally would not increase the output by the same proportion)? Your question about layers of identities is also a good one.
For any particular identity it shouldn't be too hard to do this yourself 'by hand'.
1) exclude C, I G, NX
2) bump up each of their values by 1%
3) solve the model
4) reinclude C, I, G and NX one by one generating add factors as you go.
But for the moment you'd have to do this on an ad hoc basis for the particular identities/variables.
Return to “Models”
