License manager crashes everyday
For questions regarding EViews License Manager.
navneet.sharma
Postby navneet.sharma » Tue Oct 15, 2013 7:25 am
The EViews license manager application and service crashes every morning on our license server. The server is running Windows Server 2003 R2. Below are the application and System logs. Seems like the application crashes and the service stops as a result. I have configured the service to restart after the crash. And, it does is successfully every time.
Application log:
Event Type: Error
Event Source: Application Error
Event Category: (100)
Event ID: 1000
Date: 10/15/2013
Time: 2:08:08 AM
User: N/A
Computer: xxxxxxxx
Description:
Faulting application eviewslm.exe, version 7.0.0.1, faulting module eviewslm.exe, version 7.0.0.1, fault address 0x000222be.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 65 76 69 ure evi
0018: 65 77 73 6c 6d 2e 65 78 ewslm.ex
0020: 65 20 37 2e 30 2e 30 2e e 7.0.0.
0028: 31 20 69 6e 20 65 76 69 1 in evi
0030: 65 77 73 6c 6d 2e 65 78 ewslm.ex
0038: 65 20 37 2e 30 2e 30 2e e 7.0.0.
0040: 31 20 61 74 20 6f 66 66 1 at off
0048: 73 65 74 20 30 30 30 32 set 0002
0050: 32 32 62 65 22be
System log:
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7031
Date: 10/15/2013
Time: 2:08:09 AM
User: N/A
Computer: xxxxxxxx
Description:
The EViews License Server service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 60000 milliseconds: Restart the service.
Thanks in advance everyone.
-navneet sharma
Re: License manager crashes everyday
Postby EViews Steve » Tue Oct 15, 2013 11:56 am
Navneet:
Please contact me via email at steve@eviews.com. I'd like to debug this issue with you with a different version of EViews License Manager...
cuneyt
Postby cuneyt » Mon Oct 21, 2013 4:43 am
Dear Steve,
We are facing the same problem in our univesity.
Eviews service stops with the same error codes.
This is started on middle of August.
At the begining it was happening every two weeks.
But now, it happens every two or three days.
Did you find any solution for this issue?
Best regards
Cuneyt
Postby EViews Steve » Mon Oct 21, 2013 7:38 am
Cuneyt:
I'm pretty sure that it has something to do with changes in security permissions in regards to the license.txt files that the License Manager is storing in it's own directory. A simple re-install of the license manager service will fix it. However, if you're willing, please email me directly at steve@eviews.com and I'll send you a debug version that we can use to confirm what is going on on your server. That'll help us figure out what exactly changed...
Return to “License Manager”
