Johansen cointegration test
rosemaryam
Postby rosemaryam » Fri Oct 18, 2013 11:30 pm
hi
I have questions.
for J.c can i use raw data?
for estimating lag for J.c we use var s lag estimating for it.my question is about that for J.c test can i use var lag or i shoud use (var lags-1)?in some refrences i see for example if var lags were 3for J.c they use 2.
Chuvaekek
Re: Johansen cointegration test
Postby Chuvaekek » Sat Oct 19, 2013 10:01 am
the data should integrated of the same order. non stationary at level and stationary in 1st difference. you could run the modified data instead to avoid confusion on lag selection
rosemaryam
Postby rosemaryam » Sat Oct 19, 2013 9:59 pm
thanks.
can u explain me.how can i modifiy data in eviews?
