Decomposing monetary shock into positive and negative shocks
emeraldmayowa
Postby emeraldmayowa » Thu Oct 17, 2013 2:58 am
Good day house, am trying to decompose a monetary shock from a SVAR equation into positive and negative shocks to replicate the James Cover (1992) paper titled "Asymmetric Effects of Positive and Negative Money-Supply Shocks" using the defintion
Positive Money Shock = Max(0,E_t)
Negative Money Shock= Min(0,E_t)
Where E_t is the fundamental shock (that is the residual from the money supply equation in the SVAR model).
However, when I tried using the the @max(E_t) function in Eviews, I got the same value for all the period ranging from 1980Q2: 2011Q4. Please I need help because i don't think this is what James Cover(1992) and other authors that have used this definition got and am not convinced myself with the results. Help me on which function to use or solution on how I can decompose the series into positive and negative series.
Thank you
emeraldmayowa
Re: Decomposing monetary shock into positive and negative sh
Postby emeraldmayowa » Fri Oct 18, 2013 1:28 am
Good day Moderator, I guess i got another way out for splitting monetary policy shock into positive and negative shocks.
Pos_MP = 0.5[abs(MP_Shock)+MP_Shock)
Neg_MP = -0.5[abs(MP_Shock)-MP_Shock)
However, when i enter the following commands,
Genr Pos_MP=0.5((@abs(MP_Shock)+MP_Shock))
Genr Neg_MP=0.5((@abs(MP_Shock)+MP_Shock))
Eviews keeps telling me wrong syntax, please help me out on this expression, is very urgent.
Thank you.
Postby startz » Fri Oct 18, 2013 6:35 am
You need to use "*" to multiply.
emeraldmayowa
Postby emeraldmayowa » Tue Oct 22, 2013 11:45 pm
Yes, I had corrected the error, I omitted the multiplication sign.
