Fetch/Link issue
BadrCS
Fetch/Link issue
Postby BadrCS » Fri Oct 04, 2013 7:10 am
I created a database with a link to datastream with the Fetch function. For example, i used this Fetch command: fetch(d="DS_DB",c=l,link) LHGACRP(IN).
However, when I reopen the workfile, the link fails to update due to the parameter in the brackets.
Is there a way to avoid this conflict in the link ?
I'm currently using Eviews 8 with the latest patch.
Thank you
Re: Fetch/Link issue
Postby EViews Jason » Fri Oct 04, 2013 2:48 pm
It will be fixed in the next patch.
