LS(S=0,Z,+SHOWOPTS) STDEVWP C FRAGENTS DRAFT EXPAN GAMES POPPCT TEAMS AR(1)
Supposedly all the coefficients should start at 0. But
Dependent Variable: STDEVWP
Method: Least Squares
Date: 09/22/13 Time: 18:27
Sample (adjusted): 1951 2004
Included observations: 54 after adjustments
Estimation settings: tol= 0.00010
Initial Values: C(1)=0.07568, C(2)=0.00000, C(3)=0.00000, C(4)=0.00000,
C(5)=0.00000, C(6)=0.00000, C(7)=0.00000, C(8)=0.00250
Apparently S=0 does not start at 0. Using
param c(1) 0 c(2) 0 c(3) 0 c(4) 0 c(5) 0 c(6) 0 c(7) 0 c(8) 0
LS(S,Z,+SHOWOPTS) STDEVWP C FRAGENTS DRAFT EXPAN GAMES POPPCT TEAMS AR(1)
does. But the shorthand S=0 saves some keystrokes.
See equations eq01 and eq02 in the code. Using both Eviews 8 Sep 20 2013 and Eviews 7 Sep 16 2013 standard editions
wfcreate(wf=test_start) a 1950 2004
series STDEVWP
series FRAGENTS
series DRAFT
series EXPAN
series GAMES
series POPPCT
series TEAMS
STDEVWP.fill 0.1027475073933601,0.09058467000000001,0.1029122620820999,0.1089010089635849,0.1201975420117378,0.09141733000000001,0.09009623999999999,0.08241672999999999,0.05193774402141571,0.05761597,0.08324903,0.09662496,0.09573725,0.08316496,0.08339663,0.08801164,0.06376486000000001,0.06533477,0.06001708,0.09245352,0.07788844,0.07242656499147415,0.07337721,0.06394867599010468,0.06170581,0.07206608000000001,0.07307347,0.088834,0.0750376,0.08099268,0.07104561,0.07839835000000001,0.06462069,0.06052007,0.05518005415797234,0.07779896,0.06329833,0.06057028,0.07422470000000001,0.06093438,0.05586484,0.05970393493771553,0.06323637,0.07499280999999999,0.06827225536108017,0.0708773,0.06186301,0.05921086,0.08332833000000001,0.07628321,0.06166595,0.08049928000000001,0.09147087,0.08260375,0.08328445
FRAGENTS.fill 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,2,22,22,38,43,48,42,41,45,55,61,79,76,73,91,115,99,151,97,131,137,116,139,138,117,135,155,156,211
DRAFT.fill 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
EXPAN.fill 0,0,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0
GAMES.fill 154.8,154.9,154.9,155,154.6,154.3,154.9,154.4,154.4,154.8,154.5,158.9,162.1,161.9,162.6,162.3,161.5,162,162.5,162.2,162,161.5,154.9,161.9,162.1,161.2,161.6,161.8,161.7,161.5,161.9,107.2,162.1,162.2,161.9,161.8,161.8,161.9,161.5,162,161.9,161.8,162,162.1,114.2,144,162.1,161.8,162.1,161.8,161.9,161.9,161.7,161.9,161.9
POPPCT.fill 0.0002626888162922114,0.000258267973549664,0.0002538832486607134,0.0002497125242371112,0.0002453598426654935,0.0002410637680441141,0.0002368222776567563,0.0002325796,0.000228725781198591,0.0002249344,0.0002213967,0.0002449759631417692,0.0002680423,0.0002642122562974691,0.0002605675836093724,0.0002573301,0.0002543748,0.0002516203676350415,0.0002491205523256213,0.0002960376,0.0002926084562204778,0.0002889329,0.0002858558,0.0002831407,0.0002805653493851423,0.0002778122434392571,0.0002751849824562669,0.0002951333590317518,0.0002920238766819239,0.0002888176531996578,0.0002860604727175087,0.0002832667,0.0002805782,0.0002780249,0.0002756282337941229,0.0002731967251747847,0.0002706834638956934,0.0002682747435756028,0.0002658497833181173,0.0002633506373967975,0.0002605582,0.0002577799,0.0002548722841311246,0.0002715466252993792,0.0002688925596885383,0.0002663589257281274,0.0002639233,0.0002614051,0.0002775228640530258,0.0002750367566477507,0.0002657899167388678,0.0002630713,0.0002604402543511242,0.0002579005376901478,0.0002542166621424258
TEAMS.fill 16,16,16,16,16,16,16,16,16,16,16,18,20,20,20,20,20,20,20,24,24,24,24,24,24,24,24,26,26,26,26,26,26,26,26,26,26,26,26,26,26,26,26,28,28,28,28,28,30,30,30,30,30,30,30
equation eq01.LS(S=0,Z,+SHOWOPTS) STDEVWP C FRAGENTS DRAFT EXPAN GAMES POPPCT TEAMS ar(1)
equation eq02.LS(S,Z,+SHOWOPTS) STDEVWP C FRAGENTS DRAFT EXPAN GAMES POPPCT TEAMS ar(1)
