Minimize AIC, BIC
Nils
Minimize AIC, BIC
Postby Nils » Fri May 22, 2009 9:03 am
Does anyone know how to minimize AIC or BIC when constructing an ARDL (Autoregressive Distributed Lag) model in Eviews?
I have seen similar questions posed in other posts in this forum. Unlike those posts I would like to try let's say 10 or 11 explanatory variables in the regression. Maximum lag length could be 8 quarters. I don't expect all variables to fit in the final model but it could be worth trying all of them.
Thankful for answers.
Nils
Re: Minimize AIC, BIC
Postby Nils » Sat May 23, 2009 8:19 am
If there is anyone who has an answer to this question, I would be really thankful. I'm in urgent need!
tcfoon
Postby tcfoon » Sun May 24, 2009 2:58 am
Dear Nils,
Since you are urgently need the code for any purposes, I suggest you to use the following procedure to determine the ARDL model.
Assumed that you have 2 variables.
Step 1: Run an autoregressive process (AR) regression that is Y regress with the past value (t-j) of itself (Y). Then use the AIC or BIC to determine the best lag structure.
Step 2: Run a second regression with the Y and the selected lag length (fix lags for Y), then added the lagged X into the testing equation. By doing that you can determine the optimal lag order for your X with AIC and BIC.
The above approach is similar to the Hsiao's (1981) non-parametric causality test - Journal of Monetary Economics
Good luck and hope the above procedure helped you to solve your urgent problem.
Thank you,
Regards,
CF Tang
Nils
Postby Nils » Sun May 24, 2009 4:37 am
Thank you very much for your help!
